| | | Forums66 Topics128,037 Posts1,055,580 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | Hey fellow stovebolters, Has been over a year since I was last here to chat with ya'll. Work and the foul winter weather has kept me from any of my projects. Since summer is here and I can finally get back in to the swing of things, I have a new list of questions for the board.
I acquired a rebuilt chevy 350 engine from a late 70's vehicle. I intend on putting it in my 55' 3/4 ton pickup. I removed the original engine, ( I believe it was a 250 c.i.? Also has a 4 speed manual trans. I am pretty sure the bellhousing will fit the 5.7 no problem, but can I use the same flywheel and clutch over again.? Any fitment issues there? Thanks, Brian
1952 GMC model 473 dump truck 1951 Chevy 1500 stepside
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The original engine would have been a 235 and no the bellhousing and flywheel will not interchange. You may be able to use the clutch. If someone has updated to a 250, that bellhousing, flywheel, and clutch will fit the V-8. Fred
| | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | Thanks Fred, Found that the engine in it was in fact a 235. So my cousin Glenn gave me a bellhousin for a Chevy v-8 that he had. Along with a flywheel. Now I am gonna have to do something with my trans mount situation as this bellhousing does not have the provisions on it for the original mounts. Brian.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the bell housing came from a truck it should fit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Brian_Ostner, assuming you're asking about a 55B or second series truck, you could acquire the correct V8 bellhousing, flywheel and engine front mounts by placing an ad in the parts wanted forum, or from one of the vendors (for a front mount kit), hope that helps. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | A 55-62 V8 truck bellhousing will be a bolt-in swap, and a 63-up standard shift bellhousing for either a 6 or a V8 should work. It will have the correct rear motor mount pads. For front mounts, either an aftermarket add-on setup or the original V8 mounts and brackets would be appropriate. Do you intend to stick with the original transmission or something newer? Jerry
| | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | Jerry, I am going to stick with the original trans for now, ultimately it is getting replaced with a SM465 with a NP205 transfer case. I have matching Dana 60's to put in it sometime this summer. THey have 4.88 gears and are all painted up and ready to go with new Axle seals, u-joints, and brakes. Hope to be able to put 37's under it with enough clearance. A local spring shop came to look at it and they feel that with the correct lift springs it can be done correctly, and safely. This truck is a factory longbed stepside 3600. I love it and can't wait to drive it on the road.
