7 members (68ironhead, Bill Hanlon, Joe H, Chris's 46 / 515, Pre '68 Dave, pauld, 1 invisible), 52 guests, and 2 robots.
Topics128,185
Posts1,057,279
Members48,467
Hello, recently I brought my truck in to get a safety inspection and to my disappointment, the mechanic told me that I needed new cab mounts and supports to safety the truck. The floor, rockers and cab corners also needed work so I opted to buy a whole new used cab.
After a little searching on Kijiji, I found a Canadian cab that was ready to go about 4 hours from my place. I had temporary plates on my truck so I measured the length of my cab and it came out to almost exactly 4 feet, the same width as the space between the wheel wells on a fleetside bed...
Taking into mind the angle on the firewall I was very nervous about it fitting. So I drove the old Chevy down to pick it up and made the transaction and then loaded it up. I was very happy to see that the cab fit into the box like a glove! The low hump in the cab fit perfectly around the wheel well and locked it securely into the bed. (I was also happy to see that 2 fit men can easily load the cab by themselves)
truck1
truck2
truck3
Now begins the process of prep and paint and switching everything over to the new cab! Wish me luck bolters!
Good score on the cab!
Lots more pictures
