| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | Need an oil pan for a 216, 1939 Master Deluxe Sedan. Any sources? I found a 40-46 216 on Ebay. Is that the same? Thanks, Regmudd | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1937-39 only. 1940 started using a rear main seal on the crank and the pan changed.
See the USA in your vintage Chevrolet! My Blog | | |
