8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
38
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | Ok, I just got through sandblasting my frame completely. I have everything off that could possibly come off. So what would ya'll suggest me do from here. Would this be a good application for undercoating. Do I need to treat the metal with anykind of rust preventative. This is my first one to do so i've got your typical questions. Any help at all would be appreciated. | | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | About as many options as people that you ask. Lots of discussion here on this board and a search of the archives will get you lots of good info. Personally, I used a self etch primer over the sandblasted metal then a satin black enamel finish. If I were doing it again I would strongly consider powder coating the frame. Stuff holds up well and cost is comparable if not less than painting. Lots of guys use and recommend POR-15. I'm not sure about putting it on sandblasted metal. Just my input. You should get lots of others. | | | | | Joined: Mar 2004 Posts: 2 Junior Member | | Junior Member Joined: Mar 2004 Posts: 2 | At our shop we use Nason epoxy primer followed by SEM chassis black | | |
