9 members (3B, BC59, bluechev, MickeyP, Rusty Heaps, 37 GC, Otto Skorzeny, pauld, 1 invisible),
84
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,628 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 13 New Guy | | New Guy Joined: May 2014 Posts: 13 | I'm a new guy here and looking for ideas. I'm looking at a 51 1/2 ton with a 3 speed. I want to know how much has to change to put an original 4 speed in it. I haven't bought the truck yet but most of the others I've found in my price range also have the 3 speed. I live in the mountains with steep roads. I feel the 4 speed would be much easier to get rolling and when I was a young'en my dad had a 51 with a 4 speed so that's what I want. Do I have to change the steering column to get rid of the shift linkage or can it be removed and appear as original? I'm not dead set in this truck but leaning heavy towards it.If I need to hold out for a 4 speed truck I will but we don't have a big assortment of AD trucks to pick from aroud here. Thanks in advance for all comments. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | The 4 speed is driven like a 3 speed. 1st is a very low gear. Dad used it at a walking speed to pull stumps and big rocks. It is not synchronized and is not what you want to get rolling every time. It has a different torque tube length and a different "Ball joint" from the 3 speed. Yes you can remove the linkage and the column will look the same. It will have some mount holes that can be seen. Not a big deal. If the truck you are looking at is at a good price, and you don't mind the work, the torque tube can be be replaced if you can find one, with careful basic skills. Not a deal killer in my mind. Find a 4 speed, and the floor cover, Find a torque tube and the "ball" and you can change it all out. Sell the 3 speed, and torque tube and you might come close to even.
Steve H
| | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | Hi Thad, I take it you're probably in the Northwest part of Arkansas (which is truly a beautiful place). The overall first gear ratio with the stock 4 speed as I'm sure you recall was very low. That low 4 speed ratio wasn't so terrible when you and your dad were younger and gas was cheap, however...well, let's start here since you're looking for ideas: How do you plan to use the truck? Often or infrequently? Daily driver or work truck? City or farm? Will you be hauling rocks or mostly people?
Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | . . . It has a different torque tube length and a different "Ball joint" from the 3 speed. . . . Find a 4 speed, and the floor cover, Find a torque tube and the "ball" and you can change it all out. Sell the 3 speed, and torque tube and you might come close to even. You would not need a different length torque-tube rear end. The 1948-54 truck three speed and 4-speed transmissions are the same length. You will need any year SM420 4-speed with the torque-tube fitting; or, you can put a torque-tube fitting on the end of any year SM-420 transmission. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Wow! I thought that the tube would be different. I learned something. Is the ball assembly the same as well? Thanks!
Steve H
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Wow! I thought that the tube would be different. I learned something. Is the ball assembly the same as well? Thanks! Yeap the ball is the same also. One advantage he might have is 2nd is slightly lower in ratio than the low in the 3 spd. 3.58 to 1 for the 4 speed. Plus all three top gears (2nd, 3rd,and 4th) are synchronized. Problem is finding a 4 speed 1/2 ton universal. I had one made up from an open 3/4 ton universal and the rear part of an enclosed 3 speed universal. John | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Cool! The issues the OP faces are even less than I had thought.
Steve H
| | | | | Joined: May 2014 Posts: 13 New Guy | | New Guy Joined: May 2014 Posts: 13 | Hi Thad, I take it you're probably in the Northwest part of Arkansas (which is truly a beautiful place). The overall first gear ratio with the stock 4 speed as I'm sure you recall was very low. That low 4 speed ratio wasn't so terrible when you and your dad were younger and gas was cheap, however...well, let's start here since you're looking for ideas: How do you plan to use the truck? Often or infrequently? Daily driver or work truck? City or farm? Will you be hauling rocks or mostly people?
Jon First off yes I live in NWA and feel blessed to live here. As far as driving the truck it would be occasionally. I would give it a restore and a flat/stake bed. Other than the bed it would be close to original. As far as gas being cheaper when I drove my dads truck I have no idea how much gas was then. He bought the gas and I burned it. Sometimes I just sat on the seat and pretended to drive. That was over 40 years ago but I remember it like it was yesterday. LOL Thank you to all who commented on this. Y'all are a great bunch. Thad | | | | | Joined: May 2014 Posts: 13 New Guy | | New Guy Joined: May 2014 Posts: 13 | . . . It has a different torque tube length and a different "Ball joint" from the 3 speed. . . . Find a 4 speed, and the floor cover, Find a torque tube and the "ball" and you can change it all out. Sell the 3 speed, and torque tube and you might come close to even. You would not need a different length torque-tube rear end. The 1948-54 truck three speed and 4-speed transmissions are the same length. You will need any year SM420 4-speed with the torque-tube fitting; or, you can put a torque-tube fitting on the end of any year SM-420 transmission. Please forgive me for this but is the torque tube the enclosed drive shaft tube? Could I use the torque tube fitting from a 3 speed on a 4 speed? Sorry for the dumb questions. I have quite a bit of mechanical experience but not on these old trucks yet. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | They are not dumb questions.
The enclosed drive-shaft is also called a torque-tube.
The torque tube fitting is integral to the 3-speeed transmission case. The torque-tube fitting is a bolt-on part of the 4-speed transmission.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Actually it is an enclosed driveshaft on these..... No torque is transmitted through the enclosed driveshaft. The leaf springs transmit the "push" or "pull" when in motion. The universal has a slip joint. Pre'49 Fords, Mercurys and Lincolns had torque tubes. "push or pull" was transmitted by the front of the torque tube pushing or pulling on the rear of the transmission. The universal was fixed on these with no slip joint.
John | | | | | Joined: Jun 2010 Posts: 5 New Guy | | New Guy Joined: Jun 2010 Posts: 5 | Agree with Whitelightning, no engine torque transmitted.
I think it was so called because it absorbed/controlled the torque of the rear axle housing wind-up. Seem to remember reading that here on the forum.
'54 3104 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The term used by GM in Shop Manuals (and other GM documents) was torque tube drive (as apposed to a Hotch-kiss drive). That might be technically/mechanically incorrect but it is/was a commonly used (misused?) term to describe equipment in these trucks. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I always heard the advantage with a torque tube or enclosed drive shaft was the grass in the fields did wind up around the driveshaft......LOL
The enclosed and torque tube you don't have to worry about pinion angle changing under acceleration.
Disadvantage is more un-sprung weigh.....
