| | | Forums66 Topics128,211 Posts1,057,471 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | Im working on a 40 chevy truck. When i bought it was completely disassembled. I want to "mock up" the front clip(fenders to running boards, fenders to grill shell, and grill shell baffle, grill etc. Need help to find what type of hardware is needed. Thanks | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If you're just mocking it up you can use 1/4" bolts, but I'm sure someone else can tell you what is the correct hardware. | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | CenCal53, I live in Santa Cruz & recently completed most of the steps you are inquiring about on my 37 after painting. I know the grill & fenders are different but I'm pretty sure the bolts are all the same. I don't remember the exact bolt sizes but can pull some of them off & find out for you. You're welcome to come by & see how mine goes together if it may help. I also some of the old bolts that didn't break during disassembly if you need them so you can get correct size replacements. Pm me for my address if you want to come by.
| | | | | Joined: Feb 2003 Posts: 1,384 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,384 | If a 40 is similar to a 37 I think most bolts to attach the fender to the core support are 1/4 20 with two 5/16 or 3/8 carriage bolts to mount the core support to the frame and 4 3/8 bolts to attach the inner fender mounts to the frame. | | |
