1 members (Ponchogl), 115 guests, and 4 robots.
Topics128,099
Posts1,056,506
Members48,444
#1032025 05/29/2014 5:11 PM
V
V Offline
Any repair panels for rear burb fenders avail.??
Y
Y Offline
None that I'm aware of. Depending on where it is damaged you could try to piece in a repair panel from a junked fender (long shot). This is what I'm going to do.
Marc
1 Offline
I made my own patch panels. How bad are your fenders? What areas need repair?
V
V Offline
I guess kind of a usual spot--at the rear bottom corners.
1 Offline
I fabbed that piece from scratch. I only did one side, so when I do the other side , I'll post step by step pics. It only took an hour and I wasn't busting my but to make it. Took my time. Hammer , dolly and cut off wheel and some scrap steel. I'll check the gauge.
V
V Offline
looking ahead to see what you did. That's not something I have a great deal of experience in so seeing someone else's work will be great and learn from it.
Did the same thing...fashioned my own piece. My part was missing completely...it was about 4 inches of the curve going into the tire and part of the wing at the bottom. Formed the curve piece around a piece of half inch solid steel, lots of tapping, a little stretching, some shrinking and walla! It goes down to the brace bolt hold.
Looking at it...you would not even blink...you would notice a little if you look from inside...I do metal work to within about a sixteenth(?) of an inch...not a Pro...just retired and have time to try stuff...too many do tons of bondo...I just took out two, one, and one, and one half of inch gum/bondo in a couple of places...the two inches was on the grill.
Try working the metal...I hated it at first...now it is just common sense. I don't get things many times super perfect, but mine is going to be on the road and working lots...so within a couple of months it will have bugs and chips on the front...thats a promise! Oh, the places that I have trouble are super long dents...I don't slap on bondo even for those...which many times might be a sixteenth or quarter inch spread.
rod
V
V Offline
I guess its practice makes perfect--I'll have lots of practice still waiting on the perfect part.
