| | | Forums66 Topics128,035 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 124 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 124 | I am preparing to remove my bed and cab to do some rust repair and I'm getting inspired to get rid of the in cab fuel tank while I'm at it. What is the easiest/cheapest route to go? I know lots of tanks can be made to fit in between the frame rails on the rear. With that said; I have access to thousands of cars at a local Upay and Pull yard. The thing is they punch a nickel size hole in the tanks to drain them. Is there any way to fix these?--They still seem to sell a lot of tanks with the hole so there must be a way to repair them? Thanks..... | | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | Radiator shops can clean and weld the gas tank or clean it so you can weld it | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Radiator shops can clean and weld the gas tank or clean it so you can weld it Agreed!  The radiator shop will steam clean the tank... that's really the only proven method to clean a tank that had petrochemicals in it. They will likely also be able to weld up that nickle sized hole for you too! | | |
