Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (WICruiser, Joe H), 148 guests, and 5 robots.
Topics128,283
Posts1,058,513
Members48,490
#1031905 05/29/2014 1:50 AM
I am looking for some door weatherstip for my second series 55 truck. Have any of you guys ever purchased the kit from the Truck Shop in Orange Ca.? If so how did it fit? I am looking at the one they have with pre installed snap in fastners. Saw that some members recommend Steel brand. Called them up and told them i saw two applications for my truck on there site. They told me one is shorter due to some people having fitment issues with the regular one.
truck and car shop has Counterparts rubber, made in Asia, I'd recommend Steele, #1 product - their 2nd seal isn't "shorter", it's slightly smaller in cross section [thinner] because some folks had problems adjusting the doors so they close properly, I don't think that's common ... the seals you want are the vulcanized single piece ones, like Steele has, shaped correctly with mitered corners .... and yes, you want the ones with the clips, but be aware that you'll be best off if you glue the seal around the dog leg, and you need the retainer for under the bottom edge
