7 members (Gray_Ghost, JoergK., Peggy M, oldieoldie, dbwr, 2 invisible), 186 guests, and 3 robots.
Topics128,191
Posts1,057,348
Members48,469
#1031823 05/28/2014 6:35 PM
I found a good deal on a recently rebuilt engine that I'd like to put into my '57. Unfortunately the PO painted it chevy orange. I'd like to re-paint it an appropriate 6 cyl color before installing it. It only had a few miles after the rebuild so it's not dirty at all. I'd like to just wash it good, go over it with a scotch brite pad, and re-paint with the correct color for a '57 truck which I believe to be grey. Will this work okay? I don't want to have the new paint peeling off and leaving me with an orange / gray dalmatian looking thing under the hood. Any advice will be appreciated.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #1031856 05/28/2014 10:06 PM
I've had good luck after prep. is to wipe down with rubbing alcohol that will removes oil residue . I'm sure somebody will knock this idea down , But it works for me .... No heavy coats ....
" STUCK IN THE '50'S "
jfnar #1031873 05/28/2014 10:59 PM
My '46 had the engine rebuilt by the PO shortly before his passing. It was painted the orange color too. The engine sat, never having been started for some 20 + years. I decided to use the blueish grey color engine paint too. Last fall I used acetone to remove all the orange paint to get to clean bare metal. Time will tell if my approach holds up. But, at least the orange color is gone. I applied two coats.
jfnar #1031884 05/28/2014 11:45 PM
Sir Searchalot
Sir Searchalot
Always better to go to bare metal. Big job on a engine if not on stand. Any chip offs will show bright orange. If the orange is the wrong paint or not cured properly it will give up. If a real nice restoration effort underway...gotta go to bare metal otherwise no guarantees. Even if paint first with POR 15 system there is no guarantee without bare metal.
If just a driver, won't hurt to try a paint over. just labor.
