| | | Forums66 Topics128,186 Posts1,057,324 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I found a good deal on a recently rebuilt engine that I'd like to put into my '57. Unfortunately the PO painted it chevy orange. I'd like to re-paint it an appropriate 6 cyl color before installing it. It only had a few miles after the rebuild so it's not dirty at all. I'd like to just wash it good, go over it with a scotch brite pad, and re-paint with the correct color for a '57 truck which I believe to be grey. Will this work okay? I don't want to have the new paint peeling off and leaving me with an orange / gray dalmatian looking thing under the hood. Any advice will be appreciated.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I've had good luck after prep. is to wipe down with rubbing alcohol that will removes oil residue . I'm sure somebody will knock this idea down , But it works for me .... No heavy coats ....
" STUCK IN THE '50'S "
| | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | My '46 had the engine rebuilt by the PO shortly before his passing. It was painted the orange color too. The engine sat, never having been started for some 20 + years. I decided to use the blueish grey color engine paint too. Last fall I used acetone to remove all the orange paint to get to clean bare metal. Time will tell if my approach holds up. But, at least the orange color is gone. I applied two coats. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Always better to go to bare metal. Big job on a engine if not on stand. Any chip offs will show bright orange. If the orange is the wrong paint or not cured properly it will give up. If a real nice restoration effort underway...gotta go to bare metal otherwise no guarantees. Even if paint first with POR 15 system there is no guarantee without bare metal. If just a driver, won't hurt to try a paint over. just labor.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
