0 members (), 170 guests, and 7 robots.
Topics128,078
Posts1,056,035
Members48,433
#103174 02/03/2004 2:02 AM
Junior Member
Junior Member
If flux core wire(mig) is used on body work does the flux have the same result as the flux used in brazing? Does it cause the filler to come off in time. I use a lot of flux core on other stuff and my cylinder is straight argon for aluminum use. Now I need to weld some sheet metal that needs filling.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
#103175 02/03/2004 3:51 AM
Anonymous
Unregistered
Anonymous
Unregistered
While pure argon might not work as well as a argon CO2 mix it is far superior to flux core. Use the Argon for both just be sure you have good penitration.
#103176 02/03/2004 4:01 PM
the co2 helps with the penetration of the welding, or if you can get a bottle of pure co2, even pick up one for those drinking fountans,may work better than the pure argon
#103177 02/03/2004 6:24 PM
Anonymous
Unregistered
Anonymous
Unregistered
Pure CO2 is not really a good idea. Weld done with pure CO2 are crack prone. Stick with the argon and turn up the heat.
#103178 02/03/2004 6:46 PM
To answer your question 46, I would think any flux residue should be removed prior to bondo or painting. I think you will be better off with the shield gas, as others have alluded to. I tried to save on the cost of a gas bottle and initially used flux core wire in my MIG but it splattered like crazy (regardless of the polarity) and made crappy welds. I make much better welds with a CO2/argon mix.
#103179 02/05/2004 3:15 AM
Junior Member
Junior Member
I usually use the straight argon with the flux core any way. Just did not know if i would be able to weld sheet metal with non flux core and pure argon. On fenders penetration is not a real issue. They are thin to start with. I will still use the flux core most of the time since it will be on equipment, angle or chanel. I bought the argon to weld aluminum just hoping i could cheat a little on thin sheet metal.
