1 members (Uncles51),
105
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 39 Junior Member | | Junior Member Joined: Nov 2003 Posts: 39 | If flux core wire(mig) is used on body work does the flux have the same result as the flux used in brazing? Does it cause the filler to come off in time. I use a lot of flux core on other stuff and my cylinder is straight argon for aluminum use. Now I need to weld some sheet metal that needs filling.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | While pure argon might not work as well as a argon CO2 mix it is far superior to flux core. Use the Argon for both just be sure you have good penitration. | | | | | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | the co2 helps with the penetration of the welding, or if you can get a bottle of pure co2, even pick up one for those drinking fountans,may work better than the pure argon | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Pure CO2 is not really a good idea. Weld done with pure CO2 are crack prone. Stick with the argon and turn up the heat. | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | To answer your question 46, I would think any flux residue should be removed prior to bondo or painting. I think you will be better off with the shield gas, as others have alluded to. I tried to save on the cost of a gas bottle and initially used flux core wire in my MIG but it splattered like crazy (regardless of the polarity) and made crappy welds. I make much better welds with a CO2/argon mix. | | | | | Joined: Nov 2003 Posts: 39 Junior Member | | Junior Member Joined: Nov 2003 Posts: 39 | I usually use the straight argon with the flux core any way. Just did not know if i would be able to weld sheet metal with non flux core and pure argon. On fenders penetration is not a real issue. They are thin to start with. I will still use the flux core most of the time since it will be on equipment, angle or chanel. I bought the argon to weld aluminum just hoping i could cheat a little on thin sheet metal.
