10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible), 94 guests, and 3 robots.
Topics128,062
Posts1,055,847
Members48,428
A while back there was some discussion about the mounting of the kick-down switch on a 235.
Today I got a chance to take some pictures of a customers 1955 2nd truck.
Unfortunately the switch mount is not stock but the rest looks like it is.
I hope this helps someone trying to set one up. Link to pictures
My Blog
Interesting bracket design. I wonder if the switch is stock or if the switch and bracket came off another make.
Look familiar. Its from a 60's Ford. It was an improved version of what the Y-Blocks used.
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/$%28KGrHqR,!lgE5uuTHB48BOwYJOzbt!~~60_35.JPG
There is a good diagram of the bracket, switch, and throttle rod in the 55-59 truck assembly manual, R.P.O. 315 sheet 200.
It doesn't give the bracket dimensions however.
Fred
