| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A while back there was some discussion about the mounting of the kick-down switch on a 235. Today I got a chance to take some pictures of a customers 1955 2nd truck. Unfortunately the switch mount is not stock but the rest looks like it is. I hope this helps someone trying to set one up. Link to pictures
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Interesting bracket design. I wonder if the switch is stock or if the switch and bracket came off another make. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Look familiar. Its from a 60's Ford. It was an improved version of what the Y-Blocks used.
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/$%28KGrHqR,!lgE5uuTHB48BOwYJOzbt!~~60_35.JPG | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | There is a good diagram of the bracket, switch, and throttle rod in the 55-59 truck assembly manual, R.P.O. 315 sheet 200. It doesn't give the bracket dimensions however. Fred
