0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 8 Junior Member | | Junior Member Joined: Jul 2004 Posts: 8 | my 52 half ton has rust on the floorboard mainly in front at the bend where it anlges up at about 40 degrees to form the pan behind the clutch, brake etc. Is this fixed by patching or can new metal be bought? Thanks all | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | | Anonymous Unregistered | | Anonymous Unregistered | If the rust through is not too large you can splice in a new piece of 16 or 14 gauge. Since this area is also covered by your florr covering you might be able to do an overlay of new material but that is a corner cutting method. The only patch panels I have seen for that area go from the toe board seam back to the front of teh seat. Nothing says you have to use the whole panel though. Be aware that your forward cab mounts are in that specific area also. They tend to trap the moisture which causes the rot in the first place. They may need replacing or patching also. | | | | | Joined: Apr 2003 Posts: 37 Member | | Member Joined: Apr 2003 Posts: 37 | I had a similar problem on my '51. I ended up replacing the entire floor in front of the seat, but instead of replacing the entire toeboard for a few bad spots at the bottom edge, I cut out the bad spots and but-welded new metel in.
BiggerHammer "The key is in knowing where to hit it" | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | The exact same thing I did with mine BigHammer. Finishing some sanding and after I figure out what to do with transmission panel, then I am going to prime, then Ryhno liner the bottom. When everything is dry, going to spray my main color on top of that. To see if I like the color.
popcorn The Truth is Out There (If I don't like it I'll take it off! Trial and Error I love it) | | |
