2 members (klhansen, Eisenholtz), 44 guests, and 5 robots.
Topics128,023
Posts1,055,373
Members48,420
#103160 07/13/2004 4:11 AM
Junior Member
Junior Member
my 52 half ton has rust on the floorboard mainly in front at the bend where it anlges up at about 40 degrees to form the pan behind the clutch, brake etc. Is this fixed by patching or can new metal be bought? Thanks all
#103161 07/13/2004 11:31 AM
#103162 07/13/2004 8:23 PM
Anonymous
Unregistered
Anonymous
Unregistered
If the rust through is not too large you can splice in a new piece of 16 or 14 gauge. Since this area is also covered by your florr covering you might be able to do an overlay of new material but that is a corner cutting method. The only patch panels I have seen for that area go from the toe board seam back to the front of teh seat. Nothing says you have to use the whole panel though. Be aware that your forward cab mounts are in that specific area also. They tend to trap the moisture which causes the rot in the first place. They may need replacing or patching also.
#103163 07/14/2004 9:44 PM
I had a similar problem on my '51. I ended up replacing the entire floor in front of the seat, but instead of replacing the entire toeboard for a few bad spots at the bottom edge, I cut out the bad spots and but-welded new metel in.
BiggerHammer
"The key is in knowing where to hit it"
#103164 07/15/2004 2:00 AM
The exact same thing I did with mine BigHammer. Finishing some sanding and after I figure out what to do with transmission panel, then I am going to prime, then Ryhno liner the bottom. When everything is dry, going to spray my main color on top of that. To see if I like the color.
popcorn The Truth is Out There (If I don't like it I'll take it off! Trial and Error I love it)
