4 members (Wayne67vert, Phak1, Peggy M, WICruiser), 127 guests, and 4 robots.
Topics128,111
Posts1,056,243
Members48,437
All the parts on the way for a new clutch package for a 235 in front of a T5.
I have NONE of the original linkage for the '47-'54 truck and I am going to be using hanging pedals.
The original setup had the pedal pulling on the fork from the tranny side of the belllhousing, or vice versa?
My idea is to fab a bracket of some sort to mount a basic clutch cable to the fork, forgoing both linkage and hydraulics. Has anyone done this/have pictures/seen pictures?
My question, is why are you trying to reinvent the wheel? Since you are using the original bell housing, the original pedal set up works just fine with a T-5. I'm sure that you can find the original missing parts which you would need pretty cheap.
I've driven trucks both with the original pedals and with hanging pedals. It seemed to me that the hanging pedals gave a little extra leg room, were more comfortable, and were easier to adjust.
As for the linkage - comparing the original linkage to a wheel seems too complimentary. Is a clutch cable not vastly more simple, reliable, and easier to repair/replace than the original linkage?
I mean these questions sincerely. Correct me if I am wrong.
Nothing wrong with firewall mounted pedals. What is your opposition to a hydraulic slave cylinder? Avoiding the additional work? grin
Drew
No opposition aside from the extra parts. If a clutch cable can be made to work that eliminates the expense of the master cylinder, the slave, and the bracket. If the cable doesn't work, it'll be the hydro.
BUT, if you know of a bracket to mount a slave to a 216 bellhousing, please let me know.
Unfortunately I only know of 1955 and up, but here is a link to Novak that would give you an idea of what to use. Maybe you or a friend could fab the bracket? It's pretty basic if you can figure your dimensions.
http://www.novak-adapt.com/catalog/clutch/kit_hcrc.htm
Drew
All I needed to hear was "leg room". There ain't much in these trucks. Back when these trucks were built, the bigguns must have been relegated to riding in the back, or on the back of the big horse. Invent away my brother. That's half the fun anyway.
I think he got what he was from Novak by the looks of it.
But I know I saw someone use a clutch cable on their AD. I just don't remember how they did it.
