| | | Forums66 Topics128,094 Posts1,056,465 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Kind of a 2 part question:
A: What is the role of the pilot bushing? What does it do?
B: Why the PB and TOB need replacing when switching transmission? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the pilot bushing keeps the trans input shaft properly lined up, otherwise it'd be flopping around, and it provides a "wear surface" that acts like a bearing, they can wear out and get loose - the primary reason to replace the 2 [and the clutch pak as well] is so you don't have to pull the trans again when any of them cause problems a short while down the line ... and throw out bearings can have a shorter life than the clutch disk depending on how the operator treats it ... if all have been recently renewed, then switching transmissions doesn't necessarily require the rest, although it's prudent
Bill | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | the pilot bushing keeps the trans input shaft properly lined up, otherwise it'd be flopping around, and it provides a "wear surface" that acts like a bearing, they can wear out and get loose - the primary reason to replace the 2 [and the clutch pak as well] is so you don't have to pull the trans again when any of them cause problems a short while down the line ... and throw out bearings can have a shorter life than the clutch disk depending on how the operator treats it ... if all have been recently renewed, then switching transmissions doesn't necessarily require the rest, although it's prudent
Bill But the input shaft doesn't actually go into the pilot bushing, right? Does it push against it? I am assuming the PB being of brass allows the input shaft to smoothly rotate while in contact with it? | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Yes the input shaft slides into the pilot shaft bushing. There is a stepped down area at the very beginning that fits in there. It supports that input shaft and takes a lot of the lateral load off the main bearing at the front of the transmission. Early pilot shaft bushings were made from "Oil-lite Bronze" A porous casting with lots of holes for oil to hide in. That bushing is made to be sacrificed, it wears much faster than the expensive main shaft. Just for an easy read: http://en.wikipedia.org/wiki/Oilite
Steve H
| | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Glad I asked! So I need a PB to fit the T5 input shaft. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 |
Steve H
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The pilot bushing should be a National # PB656HD | | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | One way to remove the old pilot bushing is to pack it with grease and then use a dowel rod of the same diameter as the transmission input shaft and a hammer to force it out hydraulically. When it comes out, wipe off the grease (wheel bearing grease is good to use) and drive in the new one using a piece of wood of the same overall diameter and the hammer. Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | One way to remove the old pilot bushing is to pack it with grease and then use a dowel rod of the same diameter as the transmission input shaft and a hammer to force it out hydraulically. When it comes out, wipe off the grease (wheel bearing grease is good to use) and drive in the new one using a piece of wood of the same overall diameter and the hammer. Jon I've read that silicone caulk can be used and is less messy and less likely to splatter. I agree that it makes sense to install a new pilot bushing and throw out bearing when the transmission is out for service. The clutch pack would depend on age and performance. Resurfacing the flywheel should be considered. | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Wet tissue paper will work instead of grease. Or a tap for making threads. Get the right size tap and screw it into the bushing. When it hits the end of the crank it will start pushing the pilot bushing out.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Its not a big mess using the grease, find a dowel that fits tight into the bushing you are removing, pack it with grease, get a rag and wrap it around your dowel and hold it close the the flywheel. Take a good sized hammer and give the dowel a good quick wrap, the bushing usually comes out and the grease is contained by the rag. | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | The last time I removed one with a friend (from his truck) we used a piece of bread. Easy and easy cleanup. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A glass of wine, a little cheese and you got lunch covered also.
The tap is the best next to a set of dedicated bushing jaws on a slide hammer. DG
Denny G Sandwich, IL
