1 members (RLB),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | MY 51 half ton three on the tree shift linkages at the column are very sloppy or lose .IT seem that there are 60+ year old grommets or bushings there but bad are they available from any parts house .I am hoping this might help with getting tighter shifting. ANY feed back will be appreciated. THANKS | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 |
Steve H
| | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | THANK YOU SIR ,Maybe i will get into second with a lot less guessing . | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Talk to any old farmer who drove these trucks to death,and he'll tell you to buy two sets, one for the glove box. Once these rubber parts get some wear in them, you will suffer the dreaded stuck in two gears syndrome and have to get out and unjam it. I made some brass bushings and can feel the shifting of the transmission through the gear shifter much better and I won't have to worry about replacing them. You might be able to find bronze bushings used for worn door hinges in the 'Help Rack' at a FLAPS that will work. Another problem is excessive wear of the shift rods that go in shifter arms on the transmission. I TIG welded the missing metal back on them to tighten them up.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the bronze door hinge bushings Carl mentions are readily available [Help! #38374] and work perfectly, don't wear out
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I did the same thing, though I sourced my bushings from the local Farm & Fleet in the machinery parts section. I don't recall the part numbers, went by size.
Bill Burmeister | | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | FOUND the bushings at a local farm store AGWAY. Easy to install. NOW I HAVE A NEW problem it seems i lost the shift pattern and it is stuck in reverse.Before i put the new bushing in i drove it to the store . MUST HAVE done something stupid!!!!!!!!! ANY FEED BACK | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Make sure both arms on the shift selector are set at the same height.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 50 | I remove shifter box cover,be careful when doing this. Put it in neutral.It will look like a H in shifter box.Than line up.look on page 15or16 you will find good picture | | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | TOOK it apart found three pieces of the spring that the shaft goes through ( ONE piece was sticking up through the lever forks and it jammed it). Next stupid Question where do i get a spring to fix this .Maybe i will Shoemaker it with similar springs of the same size i have in my junk part box. thanks for feedback BJF | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | BJF, I recall seeing it someplace, check all the vendors .... if you do have to McGyver it, here's a pic that might helpBill | | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | THANKS for the pic. LOOKS like a solenoid spring 60s-70s some time it pays to keep old parts in a wood box. thanks again BJF | | |
