4 members (NJC, fonz8261, Southerntruck, J Lucas), 141 guests, and 3 robots.
Topics128,089
Posts1,056,442
Members48,443
I looked at the paint spec codes; if I understand correctly, it lists the instrument panel can be either a Medium Tan or Dark Tan. Is one color "more original" than the other? Is there a site I can see a paint chips? Also, whatever color I use for the panel, I use for the rest of the interior (except the heater), correct? Thanks for any help - am ready to start painting & just want to make sure to use the right color. Bob
This is from a 2012 discussion that we had on this subject, should still be valid to day.
Some of the guys have been using Rustoleum 7272 Dark Bronze
Metallic. It's close but not as correct as the PPG offset color
DBU/DBI 27467.
I believe this is what Gus used on his interior and it came out
real nice.
http://picasaweb.google.com/103098517476416596131/UntitledAlbum02#5573664163310346418
As I posted at the begining of this
thread, you might give TPC Global a call
and see if they could put that color they
list in a rattle can. If it is correct
then you would have the best of both
worlds, spray can and correct color.
Let us know how you make out.
Denny G
Denny G
Sandwich, IL
