| | | Forums66 Topics128,182 Posts1,057,260 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | The inner wheel bearing is sort of egged shaped roller. it almost looks like that is the way there suppose to be. it ran down the road just fine, I just replaced the wheel seal | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pjberg, those are New Departure "barrel" bearings, no longer available, although there were tapered replacements available for several years. Depending on what size you need, they may only be available in places like Ebay, hope that helps. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | The ND barrel bearings hardly ever wore out. If they are not chipped or pitted, just run them and they will last as long as you own the vehicle. | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | yeah I'm going to run them. I just have never seen them before. they look ok. Thanks for answering 3B and crenwelge. Have a happy memorial day
