1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 15 Junior Member | | Junior Member Joined: Feb 2004 Posts: 15 | My '46 truck lost its VIN plate, but thank goodness it was registered using the VIN number and not the engine number. I obtained a replacement, only to realize I had no means to stamp the numbers onto the plate. I laid it aside until my wife showed me an ad for "Harbor Freight Tools" that included three different stamp sets (1/16", 1/8", 1/4"). Well, the 1/8" set was a near perfect match to the original size and font -- and cost less than $8.00! Warning -- it does not take a heavy hammer blow to mark those repo VIN plates! | | | | | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | Actually, datatags does not restore existing tags, but makes new blanks that you have to have stamped. I just asked this service about my 36 GMC to have my VIN tag restored and he replied that he dosen't restore nor does he have older truck VIN tags. | | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | My 46 suburban has a weird set of numbers on the title which do not in any way match the plate I have. Could these be numbers off the motor or somewhere else? Jim | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Jim More than likely that number is the engine number, which was frequently used on titles back then. The only problem with doing that was if the engine is changed, then you have a title number that is no where on the truck itself! | | |
