2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
The inner wheel bearing is sort of egged shaped roller. it almost looks like that is the way there suppose to be. it ran down the road just fine, I just replaced the wheel seal
Is that right?
3B Offline
Hy pjberg, those are New Departure "barrel" bearings, no longer available, although there were tapered replacements available for several years. Depending on what size you need, they may only be available in places like Ebay, hope that helps.
The ND barrel bearings hardly ever wore out. If they are not chipped or pitted, just run them and they will last as long as you own the vehicle.
yeah I'm going to run them. I just have never seen them before. they look ok. Thanks for answering 3B and crenwelge. Have a happy memorial day
