2 members (55shaker, Paul_WNC), 75 guests, and 1 robot.
Topics128,035
Posts1,055,552
This has probaly been asked before but, i need an easy understanded way to wire a hidden start button. Subject is a 52 chev 3100 1/2 ton. Putting in an early 60s 235 with automatic trans, original key location in dash, early 70s chevy van tilt column without key. Would use floor starter button if it could be modified to use with a later starter. Anybody do this? Or ideas? Thanks
Joe
I put a regular push button in the floor where the original foot starter was when I switched to a later L6 engine (230). Just ran wires along the firewall, over to the button. 2 wires. Pretty darn easy!
You can always wire in a second single speed windshield wiper switch using the correct knob and hide it in plain sight. I am doing something similar with a set of fog lights. I have an old unity switch I am mating an old choke knob and putting in the correct choke location.
