7 members (Thomaslb, 1955 1 Series, Hanks custodian, Ridgeback, Hotrod Lincoln, Ponchogl, 1 invisible),
46
Mod | | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 56 | Will a 1951 GMC 302 bolt in place of a 1937 Chevrolet 216? I have complete vehicles for both engines. I plan on using the stock 3 speed that is in the 1940.
I would assume the front motor mounts will have to be lifted from the '51 and fabed into the '37?
thanks!
1953 Chevrolet Handyman Wagon 36k 1938 Buick 38k 1947 Hudson Commodore 18k
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If I remember correctly the GMC engines were about 2" longer than the Chevy. We put them into passenger cars way back when I was in high school but that was fifty 55 years ago and I don't recall all the details. Charlie will be along I'm sure he's the GMC guru and he'll have all the answers for you.
DG
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | if I ever change engines, this is the route I am going to take. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You will need to fabricate the front motor mount as the GMC is longer than the Chevrolet motor as mentioned. You will also have issues with the radiator to fan clearance to work out. The swap has been done many times. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
