| | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 2 New Guy | | New Guy Joined: Apr 2014 Posts: 2 | Evening folks,
On my Rockwell Tcase and my SM420 I've thought about installing elbows on the filler holes so I can overfill them. I know the Rockwells can have some top end oiling issues over time so I figured a little extra could help. Any thoughts on installing elbows and filling to top of elbow instead? This is something people with getrags do a lot.
Also, what weight/fluid are you guys putting in your Rockwell transfer cases? | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | as long as you check the level every once in a while you will not have a problem; but if you have leakers and ignore your maintenance than you may want to do that. over filling may also lead to more leakage 80/90wt hypoid gear oil ron | | |
