Guys, I am at the final stages of my restoration and I am running into a problem with the doors not being able to close when I put the lower gasket on and with a very thin aftermarket door panel. I had to put the windlace in very loose so the doors would close and now if I leave the lower gasket on the rocker panel the door will not close either, in fact I had to take the rocker panel off so the door would close with the panels on. I have had the shop take the cardboard off the bottom 5 inch of the door panel and leave just the vinyl, but with doing this I have no seal at the bottom of the door. Before I start doing something crazy with the bottom of the door area to get some clearance I want to check with you guys and see if anyone has had the same issued. Thanks Norm
