5 members (Stovebolt48, 51sub, Wayne67vert, Otto Skorzeny, 1 invisible), 89 guests, and 2 robots.
Topics128,041
Posts1,055,593
Hi gang! I am in the process of rebuilding my instrument cluster and I was toying with the idea of replacing my dash illumination lights with some colored LED's. Anyone ever done something like this or have some suggestions? Thanks, David cool
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
i ahven't doen it, but have considered it. The only real problem I can see (or can't see, which is the issue) is that LEDs work best as direct illumination. Guages tend to be back-lit, so they may come up as very dim as there won't be enough scattered light to illuminate the guage. I have seen on one site (can't remember which one, but I think it's in the Links) that has LEDs for dash lamp illimination. They have a wide angle LED cluster, I recall that they migh even have them pointing to the side, too. Might be worth checking out.
If you do it, and it works out, let us know. I may consider it, too.
OT, I have used LED lamps, the ones the kiddies use on their ricer cars for lighting under the sills, as under dash lighting. Works very nicely to add some light in the foot well area. Not too harsh, just enough to see.
Bill Burmeister
I've thought about using them as indicator lights, and bought a bunch cheap online somewhere. Also got a handful of resistors, and some of that perforated layout board. And then got distracted by something else and three years later haven't finished it.
I'd be interested in how using them as instrument lighting works out.
1 Offline
their is a tech article on the h.a.m.b. website about gauge restoration and using led's to light up the instrument panel.
do you by any chance have a link to that tech article? I would be interested in seeing it. Thanks,
David
My 1962 Chevy C-30
David,
Go to the 'tech' archive on the HAMB, read the sticky at the top, follow its directions to alphabetize the list & the look for the thread 'Interior, gages on the cheap'.
Then, join the Alliance.
Doug
I used LED's for turn signal indicators and hi-beam light Drilled them into the stock panel faceplate. Works great.
1940 Chevy KC 1/2-Ton
i have as dash lighting only on my 51 3104 ... not my gauges as i have new style gauges w/ leds.
as far as gauges go try and use a hot glue gun to hold them in place...
my dash lighting:
two direction indicators = green
one oil = red
one alternator = amber
one high beam = blue
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00328.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=IMG001.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=IMG000.jpg
... here's a trick i thought of
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=1A-1.jpg
& as turn signals
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-026-11A.jpg
the completed shots are in the roll in the camera
more photos soon
do a search on linrose lights
these are about 2-4 bucks each and you NEED a resistor to make them work on 12 volt, about 2 bucks for 5.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002845#000002
Jim & Caroline
