7 members (TUTS 59, 46 Texaco, EchoBravoSierra, UtahYork, jmoore, Otto Skorzeny, TexasA&M48Truck),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | I have a '49 chevy 3100. Not all original, 1970 engine, TH350, etc.
Heater motor and core appear original and when I put power to the terminal on the side of the motor, it spins.
Question is, what kind of terminal is it and what kind of connector do I use? Never seen one like it (never owned anything this old either). A regular push on connector won't go on. Are there special original ones I can order?
1949 5 Window 3100
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Meyer, Is it a 'bullet' connector? I remember a short pigtail with a rubber covered female or male connector. Why can't you snip it off and crimp on a insulated connector of your choice. Are you going to run this motor on 12 volts? They make voltage reducers if you're so inclined. I have enclosed a link to 'bullet' style connectors. http://www.crowbarelectricalparts.com/Bullets.htm Stuart | | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | It is not a bullet. It is a short post with a plate on top if that makes sense. Looks almost like a mushroom but with a flat top. Sorry for my horrible description, I am a beancounter Identical connector on the engine's temp sending unit... (remember 1970 250 engine) so the sending unit is on top of thermostat housing. I am planning to run on 12 volts. I hooked up the 12 volts just for a sec, hope I did not damamge it. I will get a reducer.
1949 5 Window 3100
I can visualize the little flat top post on a sending unit. This must be one of the 'not original' parts. Don't know where you would find a connector for that, other than a junk yard.
The fan motor is quite durable and some folks have skipped the voltage reducer and run it on full 12 volts. It sounds like a 747 at full throttle, and in the end, might affect it longevity somewhat.
Stuart | | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | Thanks. I have a factory assembly manual on order so I'll know more in a few days.
I am guessing i will modify a connector and solder it. Seems like if I cut the flat top off the post, there would not be much there to work with.
Thanks again.
1949 5 Window 3100
| | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I believe you can use one of the standard female "tab" type connectors (sorry I can't remember what they are called). You might have to take a flat head screw driver to open it up a bit but this should work. I have that ype of connector for the temp sending unit on my engine as well, so I think I know what you are describing.
58 Fleetside, 235, "The Old Buckin' Bronco"
