| | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | I'm currently assembling my 1950 3100 truck at a real good pace. It has upgraded brakes with a front disc brake conversion kit. The original hub is still being used with a high speed bearing replacement in there. I tried to order artillery wheels and original look baby moons this weekend from classic industries where I purchased the brake upgrade kit but they were no help at all. The original wheels will not clear the front disc brakes. The classic industries catalog mentions backspacing that varies with the wheel width. I was interested in getting tires a little bit wider than the original width that came on these trucks but nothing extremely wide, just filling up the fender wells a bit more for a nice look. There is a no return policy on the wheels ordered from classic industries so I am trying to learn a little more before spending the money. Any input or suggestions on this subject would be greatly appreciated? Is there a way to modify my original wheels to clear the rotors on the front? | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | "The Wheel Smith" might be a good place to start, give them a call and discuss what you are trying to accomplish. They have original style wheels that work with disk brake upgrades.
Also, a bit of strategic grinding on your original wheels (16") can make them clear the calipers. But, do so at your own risk. | | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | Since I have limited knowledge about a 1950 3100, are you saying that this truck originally had 16 inch wheels because mine has 15 inch wheels? Just wondering if this is why the wheels won't fit over the rotors. | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | The '50 1/2 ton came originally with 4" X 16" standard wheels. There was a 15" factory option which was for heavy duty. I am not at all familiar with the front disc upgrades, but from what I've read here, many have had to do some grinding on their brake calipers NOT the wheel. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Huck: You can grind the wheel to give clearance. The part that interferes is the wheel center to rim web. Grinding off a bit of the wheel center allows for the clearance. Plenty of strength in those old original wheels. But, again, do so at your own risk. Maybe caliper and wheel grinding is the best approach. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The vendor should know if their rims clear disc. I'm sure most of thier customers are building modified rides. I have rally wheels on my coupe with S-10 discs, no problems, not sure with aftermarket artillery wheels. I'd check with other vendor til you get an answer. Also I'm sure the wheel center is the problem vs backspacing. Good luck | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | My Wheelsmith rims arrive Wednesday, I dealt with Rex, very helpful with my limited knowledge to get them ordered. He took the time to help me figure the rims and tires i needed to fill the fender wells up. You will need to take some critical measurements so he can make the rims at the back space you need. My originals were 16" 6 lug but i switched to 15" 6 lug and he assured me a future disk brake upgrade would not be an issue. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Huck: You can grind the wheel to give clearance. The part that interferes is the wheel center to rim web. Grinding off a bit of the wheel center allows for the clearance. Plenty of strength in those old original wheels. But, again, do so at your own risk. Maybe caliper and wheel grinding is the best approach. After doing two disc installations I don't think this method will work with 15" wheels. I know it will work on the CPP kit with stock 16" wheels. On the POI kit I took some meat off the calipers. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I feel your pain and am doing exactly what you mentioned here. 15 inch wheels to clear front disc brake calipers. Wheelsmith will help you out right away. They are 92$ per wheel. I got 5 of them so mine are all the same. You can then get THEIR baby moons so they fit right on the rims without special clips. 6 lug.
I just have this problem with grinding on wheels, then putting modern radials on them. If that works, I am happy for you, but I want them balanced and ready for 75 mph plus. I am very happy with the Smoothie wheels. They are 5.5 inches and are made for modern radials. Hope this helps. I talked to Dave there. He already knew what I needed without asking for measurements. I have them, painted and ready for rubber. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | This guy ran into the same problem.... Original 16" wheels won't work with disc brakes. http://talk.classicparts.com/showpost.php?p=90628&postcount=42He used a 1/4" spacer to get the wheels to clear the caliper.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Cletis: You are most likely correct that 15" wheels simply will not fit no matter how much grinding. But, my stock 16" wheels just took a minimal amount of grinding to clear the calipers. I also suppose it makes a difference on what brake kit is used.
Regardless, I am not using my stock wheels as they will take too much work to clean up and make look decent especially with $92 options out there. | | |
