| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 60 | The steel fuel line between the pump and carb on my '39 216 (with Carter W-1) is toast, and I don't seem to see new ones available. I was about to place an order at Jim Carter for a handful of things and I see they have the line for a '55-'57. Will this work, by chance, with a little modification or is it totally different? If not, what are my options? Thanks, Dan
1939 1/2 Ton 1968 K20
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I can't speak to the part you linked to, but I replaced the line on my 230 with a piece of straight steel line from NAPA that I bent myself | | | | | Joined: Aug 2013 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 60 | Did you install some brass fittings and use a flaring tool?
Dan
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | You will need a flaring tool and a tubing bender. Depending on the total length, there may be a straight line with fittings you can bend. Check to see if any fittings will fit the fuel pump and the carb/ filter bowl connection. Use the old line as a pattern and you can bend it yourself.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I replaced mine with 1/4" copper tubing and standard compression fittings available at the plumbing department of any Home Depot or Lowes. I used what was left of my old steel tubing as a guide. Easy job...easy bending...forgiving if you goof. I used scrap pieces of 20 gauge galvanized to reproduce the clips that hold the fuel line to the vacuum line. I spread the factory clips that hold the fuel line to the engine. Here is a picture-- http://s844.photobucket.com/user/ma...981_zps68b118eb.jpg.html?sort=6&o=65 | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Did you install some brass fittings and use a flaring tool?
Dan The piece I got from NAPA already had the correct fittings on it. I think it was a 30" piece for my application | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Steel (silver) brake line will work just fine. If you find all they sell is the (greenish in color) brake like, its a different material that bends a lot easier, but will still work just fine. The tubing ends are standard fittings and will fit both the carb and pump.
Joe | | | | | Joined: Aug 2013 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 60 | Thanks for the input, everyone.
Dan
