4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Can you put hydraulic lifters into any 55 or later 235? I don't remember if there was an oil passage in the block that was just for the hydraulic lifters or just the lifters themselves. Man I hate getting old.
Steve H
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The truck blocks from 1958 onwards were drilled for hydraulic lifters, but all trucks came with mechanical lifters and a mechanical lifter cam.
Hydraulic lifters supposedly should be used with a hydraulic cam.
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Thanks! Could not remember if the block was drilled or not. Now I can answer a question for some one else. I would use solid lifters for most applications any way. Just like to keep things simple. A little noise don't bother me. But like I said this was a question from some one and..I did not know. Go figure.
Steve H
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Just to clarify, Tim said "truck blocks", but all 235's starting in 1958 are drilled for hydraulic lifter oiling, but trucks continued to used mechanical lifters.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 |
Steve H
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Another issue, is that some vendors state there are mostly poor quality hyd 235 lifter available these days, so stick with solids. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you follow the installation instructions on my Blog I have had no problems with the hydraulic lifters available now.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | There have been some concerns with Quality lifters. I don't think it is just about the hydraulic ones though. Metallurgy is part science and part craft. If and when vendors get the idea that quality matters it will get better. If vendors can sell what ever they have it won't.
Steve H
