4 members (66flea, Gdads51, TexasJim50, Shade Baby), 139 guests, and 3 robots.
Topics128,164
Posts1,056,982
Members48,458
Evening folks,
On my Rockwell Tcase and my SM420 I've thought about installing elbows on the filler holes so I can overfill them. I know the Rockwells can have some top end oiling issues over time so I figured a little extra could help. Any thoughts on installing elbows and filling to top of elbow instead? This is something people with getrags do a lot.
Also, what weight/fluid are you guys putting in your Rockwell transfer cases?
as long as you check the level every once in a while you will not have a problem; but if you have leakers and ignore your maintenance than you may want to do that. over filling may also lead to more leakage
80/90wt hypoid gear oil
ron
