5 members (1955 1 Series, Shade Baby, J Lucas, Ponchogl, 50Chevy3100), 104 guests, and 1 robot.
Topics128,160
Posts1,056,902
Members48,458
Hey All
Ive been scouring the manuals as well as the catalogs, but I cant seem to figure out how to hold down the battery on my 46 2 ton. it has just been floating around in the battery box since I owned the truck.
The box, consisting of the battery box frame, and sheet metal is intact.
But there isnt anything holding it down over the top.
please help.
Not sure about 46 but with my 38 the battery is held from the sides rather than the top. The band surrounds battery near the top and you tighten clamp at one end.
right now Im just using a giant zip tie
Jay,
I agree with kb3csw, the battery is secured by the sides vs. the top. Are the band irons, and bolts in place? I used an Optima in my 41, so I had to develop a different battery mounting system.
Paul
Lots more pictures
yes
there is 1 very long carriage bolt on the outside of the battery
and 1 short carriage bolt on the driver side of the battery
I can tighten them up but that means the rivets which arent exactly flat will push against the battery. these are the rivets, front and back, which hold the sheetmetal that goes underneath the battery.
If thats all there is, I will make a rubber shim to go between the battery and the frame and then tighten it up.
Jay,
I made a 16 ga sheet metal dummy battery box to conceal the Optima battery. I used 4 approximately 2x4 inch pieces of 1/4 mud flaps to cushion and hold the dummy battery in the battery box.
[img]http://www.surfacezero.com/g503/data/3764/2013-10-20_18_20_202.jpg[/img]
[img]http://www.surfacezero.com/g503/data/3764/2013-10-20_18_22_17.jpg[/img]
[img]http://www.surfacezero.com/g503/data/3764/2013-10-21_17_14_342.jpg[/img]
Paul
Lots more pictures
Rivets may not have been a big concern back in the day. The battery cases were thicker and batterys didn't last as long either. Just speculation.
Hi Paul
making a box is a great idea.
I think I will start with a few large pieces of mudflaps on the front and back sides - the ones that have the rivets.
Jay Brown,
I agree that the battery was held fast, but not held down! Pinched from the sides.
I have seen trucks that had thin wooden "pads" - like 8th inch balsa or something - around the sides, with holes to match the rivet heads. Equivalent to the mudflap idea you're talking about. Should work fine. I don't think it takes too much pressure to keep the batteries secure.
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Jay,
It does seem like a rather flaky design...I suppose these old trucks just lumbered along and saw little "Dukes of Hazard" style jumps. As seen in my first image above, I made a bracket that secures the battery down to the bottom of the battery box. I am not sure if an acid style battery has a tab on the bottom that could serve as a hold down point.
Michael-nice fire truck, did it originally have a 235?
Paul
Lots more pictures
