6 members (baldeagle, Shade Baby, 46 Texaco, cmayna, Peggy M, 1 invisible), 68 guests, and 7 robots.
Topics128,018
Posts1,055,342
Members48,419
#1029433 05/18/2014 5:03 AM
Can you put hydraulic lifters into any 55 or later 235? I don't remember if there was an oil passage in the block that was just for the hydraulic lifters or just the lifters themselves. Man I hate getting old.
Steve H
Steve_H #1029521 05/18/2014 6:36 PM
The truck blocks from 1958 onwards were drilled for hydraulic lifters, but all trucks came with mechanical lifters and a mechanical lifter cam.
Hydraulic lifters supposedly should be used with a hydraulic cam.
Steve_H #1029525 05/18/2014 6:44 PM
Thanks! Could not remember if the block was drilled or not. Now I can answer a question for some one else. I would use solid lifters for most applications any way. Just like to keep things simple. A little noise don't bother me. But like I said this was a question from some one and..I did not know. Go figure.
Steve H
Steve_H #1029623 05/19/2014 2:50 AM
Just to clarify, Tim said "truck blocks", but all 235's starting in 1958 are drilled for hydraulic lifter oiling, but trucks continued to used mechanical lifters.
My Blog
Steve_H #1029656 05/19/2014 5:36 AM
Thanks again to all.
Steve H
Steve_H #1029698 05/19/2014 2:54 PM
Another issue, is that some vendors state there are mostly poor quality hyd 235 lifter available these days, so stick with solids.
1946 1/2-Ton Chevy
Steve_H #1029722 05/19/2014 4:22 PM
If you follow the installation instructions on my Blog I have had no problems with the hydraulic lifters available now.
My Blog
Steve_H #1029752 05/19/2014 6:05 PM
There have been some concerns with Quality lifters. I don't think it is just about the hydraulic ones though. Metallurgy is part science and part craft. If and when vendors get the idea that quality matters it will get better. If vendors can sell what ever they have it won't.
Steve H
