| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 50 | They call it a lock 358829# it hold crank or bracket on shaft,which shifted rod goes to from shiftier box to bracket. Than rod go to 2nd/3rd gear.want to put bronze bushing in wore holes . | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | huh?? you need to clarify your question a bit and give some info about year and trans, maybe some pictures would work better
Bill | | | | | Joined: Apr 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 50 | 1950 3100 Chevy tram F300 591615# 5Gm .look like flat washer.But one end of washer is a ribbon like end or wave like. this hold bracket on shaft. there a spring between bracket an lock washer for better word The end of end of shaft is groove. Thank | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | see fig 2 here, use some words from that picture, what area are you asking about, sounds like maybe the bell crank? looking for a keeper for some part of that? Bill | | | | | Joined: Apr 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 50 | that's the part....... bell crank, it the keeper on end.I'am trying to remove. guess i could replace with a c clip.I'am putting bronze bushing worn hole | | |
