| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | I have a 1958 3/4 TON 4 SPEED. my sevice manual doesnt show the clutch pedal return spring very good as mine didnt have one. anyone have a link to show it or where to buy one. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | trans doesn't matter .... assembly manual has the pictures .... goes to a tab on an oil pan bolt, if you don't still have that [usually gone] make something for someplace, make sure it's a fairly straight pull - measure from the eye on the pedal linkage to where it hooks, find a spring to fit from the HELP rack of a parts store .... like one of theseBill | | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 |
| | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | thanks all for the help on the spring. now soon as i get the longer driveshaft cut down i got off a 1 ton. maybe i can finally move it !!!
