1 members (Woodcmiami),
72
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | The speedo on my 51 3600 rarely works and when parked it is stuck at 20 MPH, any ideas guys? Thanks. Cadee. | | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | Thanks for the tip...i will try it this weekend. Cadee | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | You may have other issues There is a positive stop, so when at rest the needle should come back to zero. ...pic... There is a weight in the needle base to help with this. ...pic... | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | I was having a similar problem and after oiling etc. it still would not move when driving. I finally found that the new needle I purchased was too thick and when I assembled it, it was pressing against the glass so it wouldn't move. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | If you have the head out of the truck. Make sure that the odometer will turn. Mine was frozen and had to come apart to clean and lubricate. Not too hard to do if you keep track of all the little bits. Enjoy!
Steve H
