6 members (Millenimech, mason86, delky, UtahYork, Otto Skorzeny, 1 invisible), 65 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#1028498 05/14/2014 3:53 AM
Where do i find the VIN on my 1951 3600 truck?
Thanks!
Cadee.
Cadee #1028523 05/14/2014 7:27 AM
Welcome to the forum.
There is no VIN. That is a modern term.
In 1951 vehicles were titled by either the body serial number or by the engine number, depending on how the jurisdiction where it was registered did it.
The body serial number should be on a plate on the driver's door jamb. The engine number should be stamped on a machined boss right behind the distributor.
Of course by now your truck could have a state assigned serial number and/or a different engine.
Cadee #1028541 05/14/2014 12:01 PM
Cadee,
welcome to the Stovebolt. If this is a Canadian truck that was registered in Ontario, they would have used the number from the plate on the driver's door jamb. That is how mine is registered and they used that number to search for an ownership in the system. The ownership database is purged on a five year cycle.
1951 1 Ton Completed
Cadee #1028617 05/14/2014 7:24 PM
If it were a Canadian truck it would not be a 3600.
Cadee #1028669 05/14/2014 11:52 PM
Yes I missed that.
Cadee #1028714 05/15/2014 3:00 AM
Ok I dont have any plate on the door jamb so it must have been taken off, or fell off sometime ago.
I do have the ownership as i just bought the truck and its now in my name and on the road, 4 days ago.
I will check the number stamped on the engine as you suggested Cletis.
When i find that number, how will i know if it is the original engine to the truck?
How do you guys know it is not a Canadian truck...is it becuase it is a model 3600 and in Canada it would have been???
Cadee...aka a NEWBIE.
Cadee #1028718 05/15/2014 3:06 AM
Yes, 3600 is an American 3/4-ton. Someone else will have to tell you the Canadian designation for a 3/4-ton.
Hard to be sure if it is the original engine unless the engine and title match. Even then it could have been swapped and the tittle changed to reflect the swap, as should have been done. Many times though the engines were swapped and the titles weren't corrected.
Post your title number format and we can determine how it's titled.
Cadee #1028764 05/15/2014 1:24 PM
1948 Models & Series Numbers General Motors Products of Canada Limited
from Rob English's www.oldgmctrucks.com
website
