1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#1028493 05/14/2014 3:33 AM
My speedometer on my '74 (I know, don't even say it) C60 dump truck isn't reading correctly. I suspect the speedo cable needs to be replaced. I am wondering if a light truck cable will fit a medium truck. It has a five speed in it. Any thoughts?
Is there a problem with the cable?
Check the cog at the end of the cable where it enters the gearbox, is it the correct cog? (might be colour coded).
Have the wheels been changed, that will throw out the speedo if sizes are changed.
AK Steve,
Welcome to the Stovebolt wave
You said "isn't reading correctly"...what does that mean? Does it work but just isn't accurate or is the needle bouncing or what??? A little more info will help us diagnose the problem.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The needle bounces around. Sometimes it reads what might be correct, then it reads zero, then it reads less that what makes sense. I suspect the cog is correct as it passed a commercial vehicle inspection not long ago. However, it could be worn. I'm suspicious of the square ends on the speedo cable myself.
Red dot, center of chest ...
AK Steve, it's been my experience that the driven gear is more likely to be the culprit. They're usually made of plastic or phenolic and the cable end tends to wear the square hole enough to round it off. You could pull the cable out and inspect it, but I'll bet you find it's still square. When metal and plastic get together, metal always wins.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
I'll crawl under there in the next couple days and take a look at the plastic part. I like easy fixes. Hopefully you guys are right.
