| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | Where do i find the VIN on my 1951 3600 truck? Thanks! Cadee. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Welcome to the forum.
There is no VIN. That is a modern term.
In 1951 vehicles were titled by either the body serial number or by the engine number, depending on how the jurisdiction where it was registered did it.
The body serial number should be on a plate on the driver's door jamb. The engine number should be stamped on a machined boss right behind the distributor.
Of course by now your truck could have a state assigned serial number and/or a different engine. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Cadee, welcome to the Stovebolt. If this is a Canadian truck that was registered in Ontario, they would have used the number from the plate on the driver's door jamb. That is how mine is registered and they used that number to search for an ownership in the system. The ownership database is purged on a five year cycle. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If it were a Canadian truck it would not be a 3600. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | | | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | Ok I dont have any plate on the door jamb so it must have been taken off, or fell off sometime ago. I do have the ownership as i just bought the truck and its now in my name and on the road, 4 days ago. I will check the number stamped on the engine as you suggested Cletis. When i find that number, how will i know if it is the original engine to the truck? How do you guys know it is not a Canadian truck...is it becuase it is a model 3600 and in Canada it would have been??? Cadee...aka a NEWBIE. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, 3600 is an American 3/4-ton. Someone else will have to tell you the Canadian designation for a 3/4-ton.
Hard to be sure if it is the original engine unless the engine and title match. Even then it could have been swapped and the tittle changed to reflect the swap, as should have been done. Many times though the engines were swapped and the titles weren't corrected.
Post your title number format and we can determine how it's titled. | | |
