| | | Forums66 Topics128,274 Posts1,058,435 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | Pulled the rocker cover off my 1945 235 to check clearances, found the intake springs had some kind of "Hat" on them. 2 of them had broken "brims" and I removed them. Did these have some sort of function? Never seen them before. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The hat is steel on this year and goes on the top of the spring retainer, but is designed to shead oil. If you run without them you are likely to use a little oil. PM me if you want replacements.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2013 Posts: 36 New Guy | | New Guy Joined: Sep 2013 Posts: 36 | They are called Oil Shields or lash caps.
I'm just in the middle of rebuilding my 1950 228 head, and required 6 of these, after a lot of searching: I've found they are very hard to get hold of, most people binned then and after a recon, no longer required as the Intake guides will have seals on them | | |
