Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (3B, DaveV, Hush, Phak1, walter74), 104 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
#1028282 05/13/2014 2:29 AM
Pulled the rocker cover off my 1945 235 to check clearances, found the intake springs had some kind of "Hat" on them. 2 of them had broken "brims" and I removed them. Did these have some sort of function? Never seen them before.
1945 1.5-Ton Chevy Big Bolt
Maynard
More pix of the old truck
The hat is steel on this year and goes on the top of the spring retainer, but is designed to shead oil. If you run without them you are likely to use a little oil.
PM me if you want replacements.
My Blog
They are called Oil Shields or lash caps.
I'm just in the middle of rebuilding my 1950 228 head, and required 6 of these, after a lot of searching: I've found they are very hard to get hold of, most people binned then and after a recon, no longer required as the Intake guides will have seals on them
