0 members (), 115 guests, and 1 robot.
Topics128,113
Posts1,056,619
Members48,450
V
V Offline
Any info on running boards?
Please provide more substance/information with your question.
Start with make, year, model/size of vehicle.
Then, indicate the type of information you are looking for.
Where are you in NC? I visit NC 2-3 times a year.
I'll be moving to NC a few years from now.
I will assume that they are for a 1947/55 Suburban, not too many earlier ones and the later ones no longer have running boards. The running boards are the same as 1/2 ton pick up trucks. the only difference is the mounting holes for the pick-ups because they used bed skirts and the suburban did not. They made rubber plugs for the suburban boards from the factory.
unless this is reference to a 1-ton 47-55 panel/canopy
Don't think so if you look at the heading. I believe that the 1 ton canopy and the panel share the same 1 ton boards too (suburbans were all 1/2 tons from the factory).
OK, George - thanks.
here is a link to the hole-plugs
Yep, 1947.2-1955.1 series 1/2 ton truck,panels share the same running boards. I'm not familiar with the canopy's
Tim
1951 3100 Chevrolet
1 Offline
Being someone in search of AD 1 ton running boards, 1/2 tons will not directly work , but can be used for patching. All 1/2 tons use the same parts there though. Pretty sure that is standard on most years.
V
V Offline
what I have is a 54 3100 Burb and the boards will need work/replacement.Didn't know what worked or didn't work. This is a new "rodeo".....
Running boards will be the least of your worries (when looking for Suburban parts). Good used running boards might be hard to find, but, at least, decent reproduction ones are available.
V
V Offline
Beginning to understand....
