12 members (Gdads51, TUTS 59, Jon G, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, 1 invisible),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,103 Posts1,056,183 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 26 New Guy | | New Guy Joined: May 2014 Posts: 26 | Newbie with a nice 1965 C-10 fleet side long bed. Has a 230 six and wondering what vehicle(s) can supply the needed parts to give me power steering. Anyone know what I need to ask the salvage yard for? PS box, pump, hoses, engine brackets for the 230, double crank pulley...? That it? What vehicles and what years will work? | | | | | Joined: Mar 2014 Posts: 40 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 40 | Get a kit from rez engineering,may go by a different name now,go to salvage yard and get a box pump and hoses from a 73-87 C10.tlThe pulleys and brackets are going be hard to find. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | The engine brackets are scarce as hens teeth for your engine. You MUST have the brackets for the 230 & early 250 with the separate intake manifold. The brackets for the later head and intake cast as one piece won't work on your engine. However, the car and truck brackets are the same,so any Chevy with a 230/250 up to about '75 or '76 will work as well as any other GM product with the same engine. See http://s1109.photobucket.com/user/R.../compairbrackets.jpg.html?sort=3&o=7 for a picture of what you can use and what you can't. Stick with the truck pump and box. Get lines for whatever year it came off of. Replace the pitman arm with a new Power steering kind. They are different. Best wishes and good hunting, Les | | | | | Joined: May 2014 Posts: 26 New Guy | | New Guy Joined: May 2014 Posts: 26 | Not totally sure what engine I have in my truck. I think it's a 230.... but if someone can tell me for sure I would appreciate it. [img] http://www.tabbnet.com/C10/C10engineShot.jpg[/img] | | |
