9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible), 243 guests, and 1 robot.
Topics128,095
Posts1,056,075
Members48,433
#102789 10/02/2007 9:29 PM
Apprentice
Apprentice
Did the 235 in 55 have a vacuum advance? I can locate a distributor (mechanical advance) but none have the advance on them. Do I need to buy the mechanical advance distr. and purchase the vacuum advance seperately? Would the engine run ok with just the mechanical advance? thanks
#102790 10/02/2007 9:41 PM
Your distributor should have a vacuum advance unit. You can buy these separately by application. I think the truck item has a different physical layout than the car one. I understand that the vacuum advance unit is primarily a fuel economy device.
Stuart
#102791 10/02/2007 11:16 PM
Riding in the Passing Lane
The vacuum unit on this is attached to the clamp that holds the dist & bolts to the engine. Evidently this is all missing.
1972 Chevy c10 Cheyenne Super
#102792 10/04/2007 11:53 PM
Apprentice
Apprentice
Where does a person buy one of these vacuum units?
#102793 10/05/2007 12:09 AM
Most of the parts vendors listed in the Links section of Stovebolt.com (this site) sell the vacuum advance unit.
#102794 10/07/2007 12:01 AM
Apprentice
Apprentice
I found the vacuum advance unit but I need another piece that connects the diaphragm to the distributor. Where suggestions on where I should start looking? Thanks
#102795 10/07/2007 4:24 PM
Put an ad in parts wanted section. I,m shure some fellow bolters have one laying around they will send you.
