| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | I have conformatic pistons I assume they were made not round ?? as all measure about .013 difference at 90 degrees. tne old rings had the dot and the beveled inside facing up both rings. NOW I got a new set of sealed power E237X the sealed power instructions shows to put dot up which has the beveled edge facing down on the second ring groove.and the unmarked ring i assume in top groove thou it doesnt say that says unidentified rings may be installed either side up. is this set ok to use ??? | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Most aluminum alloy pistons are cam ground, and that measurement sounds about right. There should be an "invar" strut cast into the pin boss area on both sides to restrict expansion toward the thrust faces of the piston, causing it to get round as it heats up. The unmarked top ring should be OK to install either way. Check the end gap on ALL the 1st. and 2nd. groove rings. A good rule of thumb on end gap measurement is a minimum of .005" of gap for every inch of bore size- - - -around .025" or so for a stovebolt-size cylinder. Since the rings also expand when they heat up, a bit more ring gap is better than not enough. Jerry
