5 members (MRMEROTH11, moparguy, Oswald, Hotrod Lincoln, Otto Skorzeny), 91 guests, and 7 robots.
Topics128,193
Posts1,057,241
Members48,465
Recently purchased another 50 chevy. The previous owner had a SM420 and a 10 bolt rear end with 2.73 gears professionally rebuilt.
I cant figure out this combination for the life of me.....just seems odd for a 250 I6 engine.
Obviously with a 7:01 first gear ratio the sm420 will push those gears just fine but does this make sense to anyone else?
I hate to just dump the transmission or the rear end but both seem odd choices. Any thoughts.
H Online: Content
The 250 will be a little hard-pressed to maintain highway speed, particularly on an upgrade with a gear that tall. Also, the non-synchronized 1st. gear will be all but useless in traffic, requiring a full stop to get it into gear without grinding, and a very quick over-rev if a 1-2 shift isn't made within a few feet of getting moving. Using 2nd. as a starting gear might require slipping the clutch a little. Even a 3.08 gear would be more likely to be user-friendly. The 2.73 was a popular option with big block engines like Olds, Cadillac, and Buick, with lots of low-end torque and an automatic transmission. Those engines could be run just above idle at highway speeds for better gas mileage. Not good with a stick shift and a low-torque engine!
Thats what I thought. I guess I will put the Muncie up for sale and possible re gear the 10 bolt. thanks
If you change the rear end to something with a better gear ratio you may find that your sm420 works just fine. Unless you are going for a rear deep rear end ratio and then want a overdrive transmission.
