8 members (TUTS 59, wilbur53, Joe H, tclederman, Charles in CA, kades51, 2 invisible),
74
7
Mod | | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 19 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 19 | Recently purchased another 50 chevy. The previous owner had a SM420 and a 10 bolt rear end with 2.73 gears professionally rebuilt.
I cant figure out this combination for the life of me.....just seems odd for a 250 I6 engine.
Obviously with a 7:01 first gear ratio the sm420 will push those gears just fine but does this make sense to anyone else?
I hate to just dump the transmission or the rear end but both seem odd choices. Any thoughts. | | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | The 250 will be a little hard-pressed to maintain highway speed, particularly on an upgrade with a gear that tall. Also, the non-synchronized 1st. gear will be all but useless in traffic, requiring a full stop to get it into gear without grinding, and a very quick over-rev if a 1-2 shift isn't made within a few feet of getting moving. Using 2nd. as a starting gear might require slipping the clutch a little. Even a 3.08 gear would be more likely to be user-friendly. The 2.73 was a popular option with big block engines like Olds, Cadillac, and Buick, with lots of low-end torque and an automatic transmission. Those engines could be run just above idle at highway speeds for better gas mileage. Not good with a stick shift and a low-torque engine! Jerry
| | | | | Joined: Feb 2014 Posts: 19 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 19 | Thats what I thought. I guess I will put the Muncie up for sale and possible re gear the 10 bolt. thanks | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you change the rear end to something with a better gear ratio you may find that your sm420 works just fine. Unless you are going for a rear deep rear end ratio and then want a overdrive transmission. | | |
